Scifi Buildings
Scifi Buildings
You can use Curvy Maps (Displacement) to create complex scifi effects quickly without needing to model or worry about topology:
kenmojr
Re: Scifi Buildings
Post by kenmojr »
Wow. Looks awesome, So where are the tutorials to do this?
Thanks kindly....
Re: Scifi Buildings
The shapes are simple Lathes and Lines.
I used this abstract greyscale image as a Curvy Map (Displacement) and as a Bumpmap.
I generated this cavity map by using "HighPass" in GIMP, it helps add contrast to the material without making the 'lower' parts too dark. Applied as Diffuse texture.
