Extrude
greycheek1
Extrude
Post by greycheek1 »
How do extrude a shape? I don't see anything about extrusion in the manual.
Re: Extrude
You can make a simple extruded shape with the Slab primitive. Just draw an outline and set the extrusion depth in the object properties panel.
You can also extrude along a path by selecting a slab and then choosing the Menu: Mesh/Brush Strokes and then drawing an extrusion curve - and ticking "Stretch"
Re: Extrude
Drawing a Slab, and converting to a Enxtrude along Path (Mesh/Brush Stroke)
greycheek1
Re: Extrude
Thanks. Is there any way to import an SVG without importing it into an existing path?
Re: Extrude
No. But the closest thing you can do is a "Create Sketch" primitive and import svg into that. It won't make any meshes, but the curves will be available to copy and use in other objects.
