Redraw Stroke
Redraw Stroke
You can now redraw a sculpting stroke you made or repeat the stroke again. "I" to clear and redraw the stroke, "O" to repeat on top of the last stroke.
The image below started with the identical stroke each time, but was redrawn by Curvy after settings had been changed. You can add a fade in or fade out to the redrawn stroke, change brush settings, or even use a completely different sculpting brush.
This is useful if you are not sure what intensity of pinch to use for a stroke as you can tweak the settings and press "I" to see the results without having to manually undo and draw the stroke each time.
