object alignment
object alignment
If I draw two wheel objects is the any way I can align them or can I draw a cylinder and then cut out the middle somehow?
Re: object alignment
In 3.0 the way I draw wheels (torus) is by drawing an almost closed C shape in a Lathe, then doing a mirror clone. The C and reflected C leave a hole in the middle. You need to turn off Cap Ends in object properties too.
If needed you can use Stitch Holes to close the loop.
Thank you.
Brilliant response.
Will enjoy trying that.
Brilliant response.
