object properties - measurements
MrMajorThorburn
Post by MrMajorThorburn »
If I create an object or select one I see the properties of the object.
If I want to adjust its size I use the slider.
If I want to create another object which is exactly half that objects size It seems to me that I can only do the sizing by eye.
Is there some way I can view measurements of the object I select so I can achieve the accuracy I am looking for?
Re: object properties - measurements
Accurate transforms are on the todo list for 4.0, however you can right click on any slider and type in an exact value for the primitives.
MrMajorThorburn
Simon, thanks for that. I can see how to use that now.
If I wanted to centre two spheres in the exact same centre how would I do that?
I am asking as I don't seem to be able to see the location of the object in the 3d space its drawn in.
Is there an option I have not enabled?
Also not an option in this version (more exact transforms and are due in 4.0)
The closest you would get in 3.0 is to enable the grid, use the 4 viewport setup and manually centre them in the front and left viewports. This will give you sub-pixel accuracy if you zoom in a little.
If you don't mind where the spheres are so long as they are centred on each other, create a copy of one sphere and then scale it up or down a bit.
MrMajorThorburn
Simon, ok. thanks. had not though about using copy/paste.
I have done that successfully.
At the moment I am trying to achieve my aim using subtraction sculpting as I believe I am not able to reach the aim using additional building.
That is because I need to position the added items accurately central to the initial object. Looking forward to v 4 for that.
