Can I import eps or bezier curves from outside the app? Export?
Can you just have a background for image reference or drawing on separate from the modeling drawing?
Can you import or export 3d obj files?
is there any scripting or other automation in the app?
Any plans for any of the aforementioned?
thx
Import export
eps & bezier - No, but might be possible with a script.
Background images for ref - Yes
Background images for drawing on - For this I paint on a textured plane inside Curvy - but painting direct to the background would be cool to add.
Import/Export 3DS - Limited 3DS export is included, but OBJ is the main format
Scripting & Automation - You can save and run "Curvy script" which is pretty much just a record of input parameters, would be cool to add python or lua at some point.
cheers,
cheers,
