Hi,
I have Curvy 3D GO and I was following along with the Curvy 3D 4.1 Drawing a Cowboy in 3D, detailing the Trenchcoat & Boot | Curvy 3D 4.1 Modelling Tutorial.
I was able to mask the trench coat object and then delete the part of the masked object, but I can't figure out how to find the option for 'extract mesh boundary' that would create lines around the cut out space.
Is this capability only available for 4.1? Is there a way to do this in Curvy 3D Go?
Thanks for you help,
Fuzznoodle
Curvy 3D GO-Extract Mesh Boundary?
Re: Curvy 3D GO-Extract Mesh Boundary?
Hi, mesh bounday extraction is only in 4.1.
You can draw a curve and set the Pull Tool intensity to 0 to drag individual points on a Line object into place.
Or you can load your model into the 30 day demo version of 4.1 to try out the Boundary command.
Fuzznoodle
Thank you, I will try this!
Great work on Curvy 3D GO. I am having a lot of fun with it.
Fuzznoodle
Fuzznoodle
