Crashes
Crashes
Curvy 3D crashes when my computer goes to screen saver mode. Also before I removed the ATI driver after a while of using Curvy 3D I can't click anything on the taskbar. I'm not sure if that's fixed by using the driver included with Windows 7 or not.
I'm using Windows 7 Home Premium 64bit. Also I tried disabling prevx and trend micro and the problems are still there.
Does anyone else have these problems? I'm thinking it's an ATI problem.
it may not be connected at all to this problem
but i have mentioned before that curvy does not seem to hand back memory correctly when one exits.
I choose new from the file menu (make sure you have saved work first) before exiting curvy.
curvy exiting does not crash my xp system but does slow it down if i forget to do the above.
@sculptor I have no idea why you might experience a slowdown, but I don't think it is related to memory.
My tests show the system memory returns to the correct pre-Curvy level each time I quit. Also I would get specific "Memory Leak" error messages if I left something unallocated.
In fact Curvy does do pretty much a "New Scene" when it shuts down, as it loops through all the objects and destroys each one. I wonder if there is some part of the process that is missed out on Exit instead of New.
