Jan. models
Jan. models
Post by bigH »
model Curvy 3D - render Bryce - love to see what you are doing !
Lovely render, Curvy the potter's friend :)
I liked this so much I made my own pottery image:
http://www.curvy3d.com/forum/viewtopic.php?p=11649
cheers :)
Post by bigH »
back at you -
I like the candlestick - it renders out very richly.
Post by bigH »
thank you - a Curvy3D test
This one will work really well as a smooth inflate - the bird shape is quite smooth and all the richness can come from the outline and texture.
At the moment it looks a bit flat and lumpy - Might be improved by using the soft highlight map for the highlight and setting the highlight to use the same colour map as the main texture to give a feather-sheen rather than a plastic highlight.
Hmm... should I see this as a challenge to make a birdie in Curvy2 :)
Post by bigH »
Simon wrote:This one will work really well as a smooth inflate - the bird shape is quite smooth and all the richness can come from the outline and texture.
Good ideas - will give it a try
A challenge for you - ok :wink:
Post by bigH »
Curvy 3D bird test 2
Nice one! I see you posted this to Daz too, and they like it :)
Post by bigH »
Who do - model in Curvy 3D - render in Bryce
This one would work well done in layers.
eg: Inflate a head blob, then from a separate image inflate the ears, and from a separate image again inflate the nose.
The mouth might need some warping/dragging, and the teeth can be separate lathes.
Post by bigH »
sounds good - thank you :)
Post by bigH »
New Spaceship - rendered in Mojo
