www.curvy3d.com Forum Index www.curvy3d.com
Software for Artists - Aartform Curvy 3D
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Curvy 3D Home
Features/Screenshots
Forum
Gallery
Download
Order Now
Building an Arch for Second Life
Post new topic   Reply to topic    www.curvy3d.com Forum Index -> Tutorials
View previous topic :: View next topic
Author Message
PostPosted: Fri Apr 23, 2010 6:49 am    Post subject: Building an Arch for Second Life Reply with quote
I built this sculpted prim arch using a Loft in Curvy. Read how below:
1) Select the Loft tool
2) Draw the large curve for the opening under the arch in Front view (I only made 1/2 an arch at a time)
3) Draw a C-shape curve at the base of the arch. You can draw this in the top view and move it into position.
4) Use the ruler tool to add straight edges, and the widget move tool with a small size to tweak the shape of the curve.
5) If you want a solid arch, move the endpoints so they line up
6) Select the C-shape curve and choose Curve/Clone from the menu.
7) Move the cloned curve into place at the top of the arch, rotating it round to vertical.
8) If your arch looks inside out when you turn off Double-Sided in object properties, you can turn the C-Shape curves the other way around.
9) [BETA] Set the resolution high and use Ambient Occlusion to automatically make shade maps and AO texture.
10) Export as sculptie for Second Life (Or use in your Curvy art!)
Back to top
View user's profile Send private message
Display posts from previous:
Post new topic   Reply to topic    www.curvy3d.com Forum Index -> Tutorials All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
