Video Walkthrough: Posing + new mesh features.
Here is a quick video to describe how to use the new features ( apologies for dodgy sound quality )
http://www.youtube.com/watch?v=60SJEEm4wiM
You can switch in and out of Pose mode by pressing 'U' and any edits you make to the position/rotation of objects is stored separately while posing.
You can pose bones and all other types of object too - but bones are special in that they only rotate round one end, and can be used for skinning.
To make posing easier when using bones - choose the option "Edit/Pose Bones Only" and then only bones can be selected in posing mode.
Also added -
1) Mesh/Explode: Separates a mesh into connected sub-objects (useful when you bring in lots of objects using inflate image. )
2) Mesh/UV Front/Back: By default when you S-Merge objects you get simple front mapping (which means if you paint on the front it goes through to the back of the object too!). If you want a different image on the back choose this option from the Mesh menu and it will split the UV map in half.
