Curvy Low poly meshes
Postby Falke88 » Fri Jul 22, 2011 10:27 am
Hey guys - I'm a real noob but really need some questions answered before buying this tool - I can't test it atm because I receive an error message (see other thread)
Questions:
Can I make good low Poly meshes like Swords etc with Curvy?
Like can I turn a high poly via a button to low poly?
So can I dynamically turn down the polygon count?
Can I make polys to triangulars? via button also?
Is it possible to export in (.dts) files? Or is it possible to add a plugin to Curvy to do so?
Well that was all - hopefully I can receive good answers!
greets
Falke88
Postby Simon » Fri Jul 22, 2011 6:38 pm
Curvy is not a poly modeller - if you need really low poly models (less than 1000) you will be better off with something like Blender.
You can adjust the number of polies in a model inside Curvy using a slider, but they will loose a lot of detail at low levels.
However, by using external tools such as MeshLab you can make good game models with Curvy.
Curvy does nto have polies or tris - it converts to quads and tris when you export to OBJ.
Curvy does not support dts.
Postby sculptor » Sat Aug 13, 2011 3:17 am
just a note
good way of making low poly swords quickly in curvy
is draw the outline with a lathe
press k key
then flatten the blade with warp flatten local tool
