Curvy 3D on Mac Dev Log
Postby Simon » Thu Nov 04, 2010 12:21 pm
It's quite hard to learn as the debugger in xcode is not helpful. But after a couple of days I think I have the basics (enough to add the Curvy menu bar!) The best bit was realising I could mix and match C++ and Objective-C in the same source files - so most of the time I just use C++.
I'm beginning to realise that there are lots of little Mac-Specific features that a Mac user will expect from an application - but that I might not know are missing, so I'll need to spend some time on that once the main functionality is working.
In any case I hope to have an early Alpha build ready in the next couple of days (Lots of graphics + functionality bugs but a good first test). Moderators only until the bigger bugs are fixed.
Postby darshie76 » Fri Nov 05, 2010 12:54 am
If this can help, Appkit has a tons of features that let you do the usual mac things with 2 lines of code :)
If i would be you i would not fight objective c and just go with the flow....i discovered that doing c++ in objective c is usually fine but is a pain to debug (unless you encapsulate your c++ in a class and just call it when needed).
I am sure that you are enjoying the experience :P
darshie76
Postby Simon » Fri Nov 05, 2010 7:28 am
I'm just about to start making dialog boxes and file load/save - so I am sure that get a good boost from AppKit - so far NSAlertPanel and NSMenu were efficient ( less code required than on Windows :) ).
Postby Curveball » Fri Jan 14, 2011 6:34 am
Just joined.
Is it Wine-ready yet?
Curveball
Postby Simon » Fri Jan 14, 2011 7:42 am
Apple is doing my head in. It is like a secret society with all its different closed languages and APIs - at least Windows is organised and well documented.
I've got the basics working with an OpenGL editor, but integrating the dialogs into Cocoa/Carbon is beyond me so far. And bizzarely the Windows OpenGL version has stopped working under Wine compared to the slower DirectX under Wine version.
wxWidgets is another option - but that doesn't seem to play well with OpenGL AFAIK.
I will probably have to find a dev who has done the same kind of transition and ask them how they did it.
Postby Simon » Fri Mar 04, 2011 8:10 pm
I've got dialog boxes working in Curvy OSX now - by ignoring Cocoa/Carbon trickiness and just drawing them myself in OpenGL!
Also fixed the view borders so objects don't overlap into each other's viewports.
Just want to get load/save file chooser dialogs working and will be ready for a new beta drop.
Postby mykyl » Fri Mar 04, 2011 9:28 pm
Excellent news Simon. Looking forward to it.
Mike
Postby jayd » Thu Jul 07, 2011 2:03 pm
Apple is extremely difficult to deal with Simon--just grit your teeth, don't give up and never mention Adobe Flash to Steve Jobs--then all will be good with the world.
jayd
Postby Simon » Thu Jul 07, 2011 2:08 pm
mmm I LOVE adobe flash as a programming language :D
Previous
