Undo, Redo
Undo, Redo
Postby motleyjust » Sun May 16, 2010 6:31 pm
I like the multiple undo, but I would like a redo.
If I'm undoing, trying to get back to a previous point, and I undo one time too many, I would like to be able to go forward without having to retrace exactly same curve or whatever.
motleyjust
Postby sculptor » Sun May 16, 2010 6:53 pm
suggest save often using a different name each time(this is good practice for most computer applications)
for example
cat1
cat2
cat3 etc
Postby motleyjust » Sun May 16, 2010 7:21 pm
I do that on with all my apps, but in order to make it as effective as a redo, I would need to save after every change. Fortunately, all the other programs I use have a redo.
motleyjust
Postby sculptor » Sun May 16, 2010 7:33 pm
the thing is lots of undo/ redo eats up memory fast and when you get into some more complex models you will be glad of that extra memory (i think)
i can make models in half an hour with curvy that used to take days with other apps; give it a little time and you will see the "method in the madness" of curvy
:D
best wishes
