2. Toolbox Panel
The tools panel provides easy access to Curvy's tools.
Left click on a tool icon to select a tool to use.
If the tool icon is dimmed out you will need to select the right type of object before it will be ready to use. For example the
curve tools usually require a curve to be selected, and the
sculpt tools require a selected mesh.
See also:
Individual Tool Reference
This panel is divided into sections:
Toolbox
The top section has general purpose tools, like selection, movement, and view controls.
Toolbox Tools Reference
Objects
Next come a set of tools for making new objects.
Typically you would choose one of these tools then draw a stroke in the main 3D viewport to instantly create a new object.
Objects Tools Reference
Curves
These tools are specifically used to draw and edit the 3D curves that Curvy uses to define primitives.
Curves Tools Reference
Sculpt
Sculpting tools are used like brushes painting on the surface of your 3D model, but instead of painting colour they paint bumps and grooves and other deformations onto the surface.
Sculpt Tools Reference
Mask
The mask tools let you select part of a mesh surface for further editing and sculpting.
Mask Tools Reference
Paint
The painting tools let you paint on texture maps, and also on the vertex colours of a mesh.
Paint Tools Reference
